Unable to log analog inputs for wideband
I'm trying to log my wideband but for some reason ever since last September-octobers dataviewer update I can't choose to record any external PIDs. and when I try to record with just the i3 the analog inputs never show up in miscellaneous or any of the other tabs. I had called tech support a few days ago but was just told to try creating new analog inputs and it should show up in miscellaneous, it does not.
Re: Unable to log analog inputs for wideband
Mike, Brian
Any update on fixing why the I3 Analog input cant datalog?
Needless Torque Calibrations
www.needlesstorque.com
I'll have to look into where this is at, I thought a fix had been pushed out.
Last i recall the tool is recording them properly, its a DV display issue.
tech@diablosport.com
My i3 is doing the same thing now. I know everything is connected correctly but it doesn't record AFR.
It has seemed to have broke sometime AFTER 3.4.1.4 version of DV.
