Hey all,
Last year I did the MDS delete on my 14 Jeep SRT. I used the i3 to turn MDS off and that's it. After getting vehicle out this year I decided to load the 93 tune in. I ran the updater via wifi and then attempted to modify and load the 93 tune. Once loaded the Jeep would not start. So I then attempted to restore stock tune and start over. It gave me an error and rebooted and when I went to try again it says vehicle not supported. I was able to get the stock tune back on. I then connect the i3 to my laptop to see if there were anymore updates. It did two more updates and I tried to load the 93 tune again.I chose the 93 "Diablo" tune and when it goes to the next screen I chose to modify parameters but it's blank. I have no option to chose PCM to modify for MDS off etc. I then attempt to load stock tune on and it errored out again. Right now the stock tune is still on the PCM after fighting to get it back on it. Thanks in advance!
Lost ability to modify parameters after update and now says vehicle not supported.
Re: Lost ability to modify parameters after update and now says vehicle not supported.
please post the info.xml file or serial number for the device.
tech@diablosport.com
Serial number is 201284530
I installed a few more updates that were available and I was able to get the Diablo tune loaded but still unable to modify any parameters. I have state inspection coming up soon and need to disable the MDS so check engine light stays off and all monitors become ready.
