Hi. Fantastic tune btw.
I cannot get the auto start/stop function to disable. I have selected it in the advanced options menu and applied the tune 3 separate times. Every other parameter is loading correctly from what I can tell. Any thoughts?
'15 F150 2.7 EcoBoost Start/Stop not working
Re: '15 F150 2.7 EcoBoost Start/Stop not working
please post the files from the i2 drive/tunes folder so we can check it out.
tech@diablosport.com
Sorry for the delay in getting this to you. I have been incredibly busy with the new year. Anyways, here is the tune file. Also, both my Ignition software and my i2 updated today. I'm sure that it was up to date when I flashed the tune to my pick up, but would that might be the cause of the auto start/stop not disabling?mikel wrote:please post the files from the i2 drive/tunes folder so we can check it out.
Im told this is fixed here, please restore the stock tune then load this update to the i2 drive and let it import the file then you should be able to disable it yourself.
Thank you. I'll try it out and report back.mikel wrote:Im told this is fixed here, please restore the stock tune then load this update to the i2 drive and let it import the file then you should be able to disable it yourself.
