Updated dataviewer, can't read logs anymore RESOLVED
Went to check some logs, before I could do that, dataviewer updated and now I get this. Any ideas what's happening? This is with the i2. Thanks.
Gʀᴀʙʙᴇʀ Bʟᴜᴇ 2017 Mᴜsᴛᴀɴɢ GT 300A
Re: Updated dataviewer, can't read logs anymore
looks like the installer was setting it up wrong, please try this:
The diags.dbe database file was getting placed in directly in the "C:\Program Files(x86)" folder instead of the "C:\Program Files(x86)\DiabloSport\DataViewer" If the user just copies that file into the correct folder everything will work fine.
tech@diablosport.com
Thank you Sir. That worked. But now problem #2. Though maybe the updates weren't compatible with the old logs so went to do a new data log to see if that would work, and the i2 won't log at all. Everything is '0' and IAT shows -40. The i2 was also updated at the same time by the way. I'm at a loss again on WTF is going on here. Worked just peachy before. Didn't wanna try loading a different tune to see if that would work. An ideas ? Thanks.mikel wrote:looks like the installer was setting it up wrong, please try this:
please update to resolve the logging issue on the device.
Bingo. Thank you Sir.mikel wrote:please update to resolve the logging issue on the device.
