mikel wrote:Not true at all.
Sensor has to be enabled inthe tune so the pcm knows to look for it, and then there may be several tables that need to be populated with realistic data to make it all work properly.
thanks for the reply is there a way you can help me out with adding the data to the tune i currently have installed? or how would i go about getting that to work propperly once i install the sensor
