Adjusting speed limiter with i3 8200
Hi sorry if it's been asked before I couldn't find anything about it. With the i3 tuner can you adjust the speed limiter or only turn it off I just want to lower it to around 80... is that possible? Thanks
Re: Adjusting speed limiter with i3 8200
no you can not adjust the actual speed... the speed is raised in the preset tunes already... so if you disable the speed limiter setting, the speed limiter will then be higher than stock...
you can not lower the speed/mph that is set in the tune...
