Board index i2/i3 Technical discussion Ignition updater i2 not working... please help
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
Post Tue Aug 22, 2017 7:28 am
i2 is not working right. Able to select "TUNE VEHICHLE" then on next screen it says make sure vehicle is run position and not on. After I click on continue it says PLEASE WAIT. at this point it does nothing else but stay on please wait. After fifteen minutes I disconnected it. I must add that the truck has a custom tune it in from the i2 and it only started this after an update from the IGNITION software. ALSO I'm unable to connect to my wifi. After I put in my password, it says please wait then after a short time it says session timed out.
Post Tue Aug 22, 2017 8:49 am
save tgis to the i2 drive and let it import the file then try tuning again please.
561-908-0040x4
Post Tue Aug 22, 2017 12:09 pm
Thanks Mike, That solved all my problems. Great tech support.
Post Tue Sep 04, 2018 2:13 pm
hi, i have a similar problem with the ignition updater because when i update my i2 for mi jeep srt8 6.1, a go to the tune vehicule, click on the advance tune and click in install standard tune and i select diablo tune and dont do anything, i cant install in my jeep. I attachment the info.xml. Please helppp
Return to Ignition updater
