Board index i2/i3 Technical discussion Ignition updater Intune I2 Stuck on preparing installer
Post here with any questions regarding the use of the Ignition updater software for PC or Mac
Post Thu Nov 29, 2018 4:41 am
I have had an intune I2 for a few years now when I go to up date it the intune gets stuck on the preparing installer. This is the first time I have tried to update it since the installer changed. How can I fix this?
ok got it past that point, but now it keeps saying 4 updates and updates then plug it back in and it ways says 4 updates then updates and same thing.
its up to date, thats a bug we are looking into.
561-908-0040x4
I am not sure here is the new info file.
It keeps doing the install loop and I am unable to get the wifi enabled. I read else where in this form about the same issue, but could not find the solution.
there is no solution at this time... read mikel's post above... the updater loop is a bug, and they are currently looking into the issue..
your tool is up to date... no need to keep trying to update it at this point...
ok thank you
Return to Ignition updater
