Board index i2/i3 Technical discussion Ignition updater Another fee to unlock?
Post Thu Mar 14, 2019 5:55 pm
Had an i3 from my RAM, purchased a GM license for my Silverado, now it's telling me I need another unlock for an additional $40?
This is confusing as hell. What did the license I purchased for $149 get me if not the ability to tune my truck?
Post Thu Mar 14, 2019 5:57 pm
purchased this...
Post Thu Mar 14, 2019 5:58 pm
and now I get this?
Post Thu Mar 14, 2019 6:52 pm
This is the notification upon updating (what I thought was the PCM unlock process).
Post Fri Mar 15, 2019 10:37 am
yep.. because 2017/2018/2019 vehicles require a special unlock sequence to unlock the ECM so you can tune it...
so what will happen is, when you go to install a tune the first time, the tool will give you a message that "one or more controllers can not be tuned - Contacting powerteq/diablosport for vehicle unlock... you will be notified within 1-2 days" - or something similar to that effect.. so then in 1-2 days (it's usually within an hour though), once the unlock code has been generated, you should receive an email (if you registered your tool on diablo's site) that your update is ready.. so then you'd run the Ignition Updater on the tool again, and it will update the tool with the unlock code for your ECM, and then you'd be able to tune the vehicle.
Well, GM has started charging all programmer companies (not just diablosport), for every single 2017+ vehicle ECM unlock code request...
So, to get the unlock code/key, you need to purchase the unlock...
then wait about 20 minutes and run the updater again to update your tool.. and then you'd be able to tune the vehicle.
Post Sat Mar 16, 2019 11:30 am
OK, so not trying to be a dick but, shouldn't the software indicate that there will be an additional charge somewhere PRIOR to purchasing a license that doesn't actually allow tuning my truck?
I was OK with 149, but for some odd reason 189 isn't OK with me, might have been had I known up front but the backhanded method to get the additional fee is, if I'm not mistaken, illegal, or at least very unethical.
Post Sat Mar 16, 2019 11:38 am
no, because how does the software know what you are going to tune??? heh... the ECM unlock key is only for 2017 or newer GM vehicles.. not ALL gm vehicles... if you had a 2000-2016 GM vehicle, there would be no additional charge for an unlock key...
Post Sun Mar 17, 2019 3:43 pm
Truly not seeing my point are you? The additional fee for my 2017 was undisclosed prior to purchase, and I believe that is some seriously shady business ethics. Perhaps reprice the 149 to 189 or at least have it say somewhere that there is an additional fee for another unlock.
Post Tue Mar 19, 2019 11:13 am
the problem is, we dont know what year GM you plan to tune, so its one price to add a gm license to the device, but then if you want to use that on a 17 or newer model, you have to pay the additional $40 required for those models. This is not a money grab on our part, its a fee that we are required to pay to support the newer GM vehicles.
561-908-0040x4
Return to Ignition updater
