New crom updates for the 7137 Rams?
I've read in some topics that there is a crom 9.05 and 06 out but the support files only list the 9.04? I am looking for better tranny shifts as my 08 feels like a manual! There is a lag in the WOT shifts. Part and 3/4 throttle it shifts fine.
RE: New crom updates for the 7137 Rams?
There has not been a 9r05 or 9r06 to my knowledge.
Any idea if part throttle downshifts will ever be available?
we can only pray
Second gear rubber in my truck with the tune and in tow/haul mode. When in traffic I sellect tow/haul-ass mode, this makes the tranny downshift and engine brake when slowing down. With the upshift parameters adjusted and the tow/haul selected this truck is fun to drive.
If delayed shifts are the issue you may have something else gong on. Do you have your rev limiter and shift points set not to bump? A higher shift point than 5600 might be the culprit.
07' RAM 5.7, Rg cab, 91oct. tune, CAI, BBK shorty's Magnaflow with true duals, 180 t-stat., 4:10 gear, 4500 lbs w/o driver. U7137X, V9t07d
