reading logs
stingragtiger
reading logs
Post by stingragtiger »
I'm getting a argument length must be greater than or equal to zero. any ideas u7193 05 5.3l newest revision i guess. Just updated 1 week ago.
here's the log if it helps.
truck2.csv
Description:
Download
Filename: truck2.csv
Filesize: 172.28 KB
Downloaded: 0 Time(s)
stingragtiger
RE: reading logs
bump
stingragtiger
RE: reading logs
oops I may need the air fuel ration.
stingragtiger
RE: reading logs
I can't find the air/fuel point to monitor!! I went through the menu twice this morning and It is not listed. anyone? u7193 newest revision. 05 5.3
stingragtiger
RE: reading logs
Just read, the u7193 doesn't have afr.
RE: reading logs
correct, you won't have the AFR parameter... but you don't need it for the LTFT adjustment or cruising log data...
the problem is, your cvs log file is corrupt.... it's all gibberish...
open it up in excel and you'll see... it's all garbage.... that's why you're getting that error from DSLogRedux...
stingragtiger
RE: reading logs
It seems to run fine in dataviewer. I can run it and watch it there, is that normal?
RE: reading logs
the .log file, yes...
so, load up the original .log file into the dataviewer again... then go to FILE > EXPORT TO CSV to save that log file to your PC as a .csv file... is that what you did before?? or did you just rename the .log file to .csv???
EDIT! YUP! that's what you did alright... you just took that .log file and RENAMED it to a .csv file... can't do that man... when the log is loaded in the dataviewer, you have to export it to a csv file, so it converts the file correctly... heh...
according to that log you posted, your average ltft's are good where they are... no need to adjust your injector slope at all...
stingragtiger
RE: reading logs
Thanks on staightening me out. I'll try it again tonight. That log is in 3rd and I have another in od on the interstate. Is it ok to be in od or should we be in 3rd or 2nd just as long as the rpms stay as constant as possible.
RE: reading logs
as long as the rpms are 1850-2200, you'll be fine
Grumpy_Aero_Guy
Re: RE: reading logs
Post by Grumpy_Aero_Guy »
stingragtiger wrote:Just read, the u7193 doesn't have afr.
Correct. But it can be logged if you log via dataviewer and a laptop in your vehicle.
LEW, yer slippin' man....... LOL
DSLogRedux.com
stingragtiger
Is it normal to bounce between +1 and-1 on the slope. One was in 3rd and the other was in od (+1). I think i got the logs right this time.
yeah, that's normal...
