2005 gt gear change
mlfskr2
2005 gt gear change
Post by mlfskr2 »
i will be swaping out rearend gears to 373 ratio. my question is, can i change the pcm stock tune with tuner and leave the tuner unlocked. or should i have the dealer reflash pcm with new gear ratio. the reason i ask is if i remove the cai and all the other parts i have put on the car to sell it with 373 gears installed. i do know i can modify my air raid canned tune.
tks in advance
2005 mustang gt 5spd
air raid cai
bbk under drive pullys
air raid t/b spacer
u7140 tuner
tuningss
RE: 2005 gt gear change
Post by tuningss »
If you have a tune installed into the car, (even a stock tune with gear change) the tuner is locked to that car.
http://www.tpctuning.com
mlfskr2
Post by mlfskr2 »
thats what i thought, thanks for reply. i will put stock tune back into pcm and and have the dealer relash the pcm with new gears and then reload my tune and make the adjustments.
tks
Return to “Predator Ford Gas”
