Check engine light on Dodge 6.7
lsimmons
Post by lsimmons »
I just installed the PPE on my Dodge 6.7 and it set off the check engine light. I checked all my connections and they are fine. Is this something that i will just have to live with? Or is this something that is not supposed to happen?
Please let me know what i need to do to fix this!! i want to keep the power puck, it is awesome!
-thanks
RE: Check engine light on Dodge 6.7
Take it to an auto parts store and ask them to read it, write down the code, and let me know what it is.
lsimmons
Post by lsimmons »
ok i will. can autozone do it?
lsimmons
Post by lsimmons »
ok i got the codes checked. It threw codes:
P-0192 - Fuel Pressure Sensor Low
P-0340 - Crankshaft Position Sensor Circuit-Bank 1, Sensor 1
P-0402 - EGR Flow Excessive
P-0405 - EGR Position Sensor Circuit Low
P-0652 - Sensor Reference Voltage 2 Low
None of these codes were there before i installed the power puck :?
I have not done anything else to the truck.....
-thanks again
Looking into this...
lsimmons
Post by lsimmons »
ok well i got a friend of mine that is a cummins mechanic to clear the codes. That was friday morning. i have not had any of them come back :D. So im guessing it just threw the codes right after i installed it or something. maybe one of the plugs was loose or something. I will let you know if any come back. Thank you for responding to this.
-Logan
Good deal, let us know.
