The iPod is tied into it thru the XM Interface. Is there a different way to bypass it or something?
What does the Predator have to do with the radio anyways? Is there any hope?
2003 Tahoe - U7193 Just Back from DiabloSport! Help!
RE: Re: RE: Re: RE: Re: RE: Re: RE: 2003 Tahoe - U7193 Just
the radio/XM interface causes a power drain on the electrical system... even tho small as it may be, it's enough to wreak havoc with the predator trying to flash the tune to the vehicle...
can't have ANY power draws...
need a fully charged battery... good electrical power/voltage..
So what I don't get is why even when I pull the fuses that it isn't working.... Are there more fuses I need to pull or something? I'm at a loss here...
Even when I pull every fuse even remotely related to the radio and OnStar it doesn't work. I don't get it.
Mike, if you thought this could be the problem then why didn't you ask me to pull fuses and such a long time ago anyways? Wouldn't this be part of troubleshooting? Just asking.
And I got the stereo and everything looked at and verified. The fuses are correctly linked to the iPod connectivity kit (when you pull the radio fuse, it doesn't charge the iPod). It's wired passive.
We have not seen fuses to be an big issue in later model trucks.
Update is still in testing currently.
RE: 2003 Tahoe - U7193 Just Back from DiabloSport! Help!
How much longer can this possibly take?
How much more testing can be done? How about having me test it since I'm the one having problems!
