Data Logging not available
johnc
RE: Re: RE: Re: RE: Data Logging not available
Post by johnc »
r17 has logging on the Predator, but exporting the log into the DataViewer has a bug.
johnc <at> diablosport.com
Jected
Post by Jected »
It certainly does. Any time soon of a fix. 8t16c worked well with Dataviewer. Thanks.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
OsuThunder
Post by OsuThunder »
awww thats ok, I dont mind having my laptop in the car.......it just makes me want to make blow off valve noises and pretend im in the fast and the furious.
johnc
Post by johnc »
You can log on the Predator and view the log on the Predator. OR you can live stream data to the DataViewer and log on the DataViewer. The only piece that is broken is transfer of a log that was created on the Predator for viewing in the DataViewer.
powerfox66
Post by powerfox66 »
is there a 'how to' on datalogging with the predator?? u7134 and has this issue with transfering the log been fixed???
powerfox66
anyone??
BlackACR
Post by BlackACR »
I've got the U7134 v9r17 with no options to Datalog, under Diagnostics menue I have -Trouble Codes, -Diagnostics, -Show Calibration ID. Shouldn't there be "Realtime Streaming, and Log Playback" to actually Datalog with?
'05 SRT-4 ACR, AEM SRI, 55mm TB, MSD wires, 3" Catless DP, stock exhaust no resonators, DSP 93 tune.
BlackACR
Post by BlackACR »
okay I did some playing around and found that using the "Real time data" can be uploaded to DataViewer. This will only hold about 5 minutes of log. Is this how much time is expected w/out being connected to the PC? It also looks like I can select more PIDs than I originaly watched in the initial "log" on the DSP.
?? Did I just figure out somthing everyone else already knew??
