Possible improper installation of Diablo Predator?
DasBach
Post by DasBach »
Hello everyone!
I purchased a Diablo Predator U7135 for my 2005 Chrysler 300C (5.7).
I updated the "calibration" on the tuner via the PC, and took it to the car and everything installed great. After the calibration, I started the car and it had a rough idle. I didn't notice any knocking or such, just a rough but steady idle. I installed the 91CAI tune and then restored it back to factory just incase, and the rough idle is still there...
Is this how the vehicle is supposed to perform? I haven't driven it yet, as I wanted to make sure I'm not about to kill my engine. It currently has 26,XXXmiles and I don't rag on it so I know its in pretty good shape.
Any help, or clarification would be great. Thank you!
You may have the early 05 MDS issue. Try disconnecting the battery for a couple minutes.
DasBach
Post by DasBach »
Will this require recalibrating the vehicle again? Whats the next step now?
No, won't require another ecalibration. Just disconnect for a few moniute so the system resets, then reconnect and see what happens. If its the early 05 problem, the car should be fine. If its not the issue will remain.
DasBach
Post by DasBach »
I disconnected the battery and everything went back to normal. I don't have any 87 tunes, just 91 and 93.
correct - no 87 octane tune for that car... you shouldn't be running 87 octane in that anyway... you need to run 91 octane or higher...
DasBach
Post by DasBach »
I run the mid-grade gas, which I'm pretty sure is 87. I always think 85 because I think the low-grade is 83. I live in AZ so I'm pretty sure its 87. I will fill it with 91 when I run low on this tank.
I didn't know they sold anything that low in the US. Should be 87/89/91 or 93
Return to “General Support”
