SRT-4 S2 w/toys not getting all PIDS?
jstaneon
Post by jstaneon »
u7134
9r17
2004 Dodge SRT-4
While talking with another Predator user talking about various PID's to log I came to realize that I didn't have the same PID's available to me as the other fellow.
Under the torque management heading I only have one PID to choose from while he says he has many...
Also it seems I am missing the entire wastegate control heading all together.
I've completely removed and re downloaded the data viewer cause the about heading didn't match what the software download page said the version was, but it seems someone just forgot to update the about page. anyway, i've re-queried the vehicle, i'm not using a dashboard, i've clicked the lightning bolt many times.
Any suggestions? Is this possibly just a difference between PCM's
I believe he is using a S1 pcm and I'm running a box stock installed S2 w/toys setup.
RE: SRT-4 S2 w/toys not getting all PIDS?
S2 may have a totally different PID list.
As I recall, it is a non emissions PCM, so it will not have lots of the stuff a emissions based PCM needs to have.
jstaneon
Post by jstaneon »
yeah I can understand emissions stuff.... but wastegate duty cycles and torque management...
this is the thread we are discussing.
http://www.srtforums.com/forums/f384/pi ... -b-529829/
but specifically talking about these.
Torque Mangment-->
TRQ DESIRED
TURBO TOTAL TRQ DESIRED
Wastgate Control-->
TURBO WG DC
TURBO TRQ POTENTIAL STP
TURBO WG ADAPT DELTA
of the Above 5 parameters I only have the TRQ DESIRED.
Just seems strange to not be able to see some of this stuff...
Try clicking the 'show infrequently used PIDs' option in DV.
Letxen3
Post by Letxen3 »
x2 i cant view those pids also.
~James 2004 PT Cruiser GT
johan
Post by johan »
Are you all using the latest version of Dataviewer and also have the show infrequently used pids checked?
If you are please post calid and year of vehicle and i will look into it.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Letxen3
Post by Letxen3 »
sorry its not that i cant view them in the DV i can not select them when i am using the handheld about to start logging.
johan
Post by johan »
Oh so you can see it in DV but not in the handheld?
Diablosport INC
Letxen3
Post by Letxen3 »
i have not been able to see it in the data viewer since i can't select/ log it from the hand held.
johan
Post by johan »
Have you tried to stream directly to your laptop and see what pids show up there?
Diablosport INC
Letxen3
Post by Letxen3 »
no i havent but someone did tell me to do that and it would be viewed that way.
jstaneon
Post by jstaneon »
Mikel hit it on the head. had to go and choose the display uncommon PID's
then re-query the vehicle and they will all show up
Thanks Again for the speedy response!
johan
Post by johan »
Yeah the Predator only has select few pids, the dataviewer with show infrquently used pids check will open up a world of pids for you.
Diablosport INC
Quick
Post by Quick »
Side question: Will the Trinity show/log all the pids the DV will?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
johan
Post by johan »
Quick wrote:Side question: Will the Trinity show/log all the pids the DV will?
Nope, same lists as predator
Diablosport INC
