U7194 Issues with update 9t08NL
CANUCKPREDATOR
CANUCKPREDATOR wrote:you just have to get them to hold the telephone closer to the screen so you can take a look.Works every time.
Problems with new Crom.
I have 07 Chevy 2500HD 6.0 gas and I have the Preditor U7194. I restored my stock tune back to the truck to unlock it and installed the new Crom file. Hooked it up to my truck and the Preditor does not reconize my truck it said your calibration is not reconized. Any ideas? I installed the 9r07 crom back to the Preditor and works ok. VIN: 1GCHK29K77E511845
SparkySparks
RE: Problems with new Crom.
Just wanted to check in since its Monday and hopefully someone’s in to have a look at the issue.
CANUCKPREDATOR
read the topic in the stickies at the top. there is a post from Johan about what to do and what they are doing.
SparkySparks
Re: RE: Problems with new Crom.
If that is directed to Firedog then yes, Johan has directions on what to do if you receive a message saying your Predator doesn't recognize your truck, still nothing about the Error(-14) and Error(-15) when trying to create a backup so you can install a tune using the update.CANUCKPREDATOR wrote:read the topic in the stickies at the top. there is a post from Johan about what to do and what they are doing.
RE: Re: RE: Problems with new Crom.
Well, good news for you Sparky, i just had a 2010 camaro here and it did the EXACT same thing you are describing, we will look at this tomorrow and figure it out, as soon as we get that sorted out we will post up a new rev for you to use.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
SparkySparks
Cool, thank you. Let me know if you need any more info or a copy of my original tune (would have to go back to rev. 9r07).
Firedog, I have the same exact problem as you. I have the same truck/engine but an 08. I have yet to get any answers why the new u7194 9t08nl crom doesn't work. I looked in the sticky's but didn't find any answers there. I read that the new update rocks, I wish it would work.
Hopefully someone here has had this same problem and can post a solution. I was however able to load the 9r07 back into the truck.
therink
2012 Silverado 3500 HD LTZ, Z71, crew cab, 4:10, 6.5 box, Stock 6.0, K&N drop in
CANUCKPREDATOR
http://www.diablosport.com/index.php?na ... 7&start=30
Read last post from Johan, not a fix at the moment, but what to do to help get a fix.
will do. Is he referring tha I email my stock backup that is in my predator now? Because it wont take a back up when I get the message "Calibration is not recognized" . It doesn't let me go that far. It gives me that message after I enter the transmission type.
therink
