Thanks All
Can someone look at my log
This is the 91 Perf tune w/+ 3% fuel added across the board. I'm seeing 0.0 LT KNK and 4.0 ST KNK. What adjustments do I need to make?
Thanks All
Thanks All
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
RE: Can someone look at my log
Hey Braodfca. I decided to play with my car yesterday and was bound and determined to get the 93 CAI program to work. I got it close by adding 15%/18%/17% to the three ranges. I screwed with that thing for four hours adding a little bit at a time and finally got most of it to disappear. I may want to add more to the mid range yet. Mine looked like some of your graph for a while. I don't know if you need to add that much to the 91 tune or not. But finally got it to get #1 spark in the 24-26 degree range in upper rpms. I kept timing it between 60-80, and sure enough as the ST knock began to disappear it got a little quicker. When you go out try to get several readings, as for some reason the logs don't always look consistent either.
What has everyone else been adding to the canned tunes? I know one thing, nothing works like E-85 on these things, but not everyone can get that stuff for the right price.
2006 300C-SRT
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
Re: RE: Can someone look at my log
Thank you my friend. So, are you saying that adding fuel may be a good place for me to start. Please bare with me as I still have a lot to learn here. I am taking baby steps with this tuning stuff.DGatzby1 wrote:Hey Braodfca. I decided to play with my car yesterday and was bound and determined to get the 93 CAI program to work. I got it close by adding 15%/18%/17% to the three ranges. I screwed with that thing for four hours adding a little bit at a time and finally got most of it to disappear. I may want to add more to the mid range yet. Mine looked like some of your graph for a while. I don't know if you need to add that much to the 91 tune or not. But finally got it to get #1 spark in the 24-26 degree range in upper rpms. I kept timing it between 60-80, and sure enough as the ST knock began to disappear it got a little quicker. When you go out try to get several readings, as for some reason the logs don't always look consistent either.
Thanks again
RE: Re: RE: Can someone look at my log
DGatzby1 - you say you're adding E85 to your 300C SRT? I thought E85 was 'bad' for our cars. Or did you mean something else?
Not that I have access to E85 in Florida...
I believe that is the only way to get rid of knock other than setting the timing lower. We don't want to do that. In fact some of my logs looked just like yours before I began to add fuel.broadfca wrote:Thank you my friend. So, are you saying that adding fuel may be a good place for me to start. Please bare with me as I still have a lot to learn here. I am taking baby steps with this tuning stuff.DGatzby1 wrote:Hey Braodfca. I decided to play with my car yesterday and was bound and determined to get the 93 CAI program to work. I got it close by adding 15%/18%/17% to the three ranges. I screwed with that thing for four hours adding a little bit at a time and finally got most of it to disappear. I may want to add more to the mid range yet. Mine looked like some of your graph for a while. I don't know if you need to add that much to the 91 tune or not. But finally got it to get #1 spark in the 24-26 degree range in upper rpms. I kept timing it between 60-80, and sure enough as the ST knock began to disappear it got a little quicker. When you go out try to get several readings, as for some reason the logs don't always look consistent either.
Thanks again
2006 300C-SRT
Re: RE: Re: RE: Can someone look at my log
I DID mean E-85. You have to get a CMR dealer to tune your car, one who knows what they are doing. You can ask DS, if anyone down there is programming for it. Here in MN we can get it for a 25-30% discount to premium gas, so it makes financial sense to run it in the summertime anyway. It don't work so well in cold weather.Lymzilla wrote:DGatzby1 - you say you're adding E85 to your 300C SRT? I thought E85 was 'bad' for our cars. Or did you mean something else?
Myself and others don't know what would be bad with running E-85. I do and it is wonderful to take advantage of its increased octane. It is basically cheap racing gas, but (hint) you need to run near a 12.1 AFR.
2006 300C-SRT
RE: Re: RE: Re: RE: Can someone look at my log
Awesome!!! I had heard that unless your car was manufactured to handle E85 there might be seal problems. Well, at least you've got the tuning side figured out. So I shouldn't be as concerned if I get stuck at a gas station where I can only get E85... I currently am running the 93 w/CAI tune.
Not likely you will find somewhere where only E-85 is sold. I think they have said we can run it with the 93 CAI tune, but I would not do it for long. I know it stretches the limits of what our injectors will put out at WOT. If you want to use it I would recommend a CMR tune.
2006 300C-SRT
