Problem with my 7194 and my Z06
CANUCKPREDATOR
Post by CANUCKPREDATOR »
make sure the stock tune is install BEFORE you do this.
johan
Post by johan »
manolis-1975 wrote:ok, will do tomorrow morning and then try the predator and get back to you!!! Thanks for all your help up to now!!! :)
Once you do that no need to send us the predator, just call us and get it reset, it can be done over the phone.
Just complain about the battery draining and they will update it for you.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Solid
Post by Solid »
Hey Johan,
Just to be ahead to things ;) can't it be done by e-mail? because Manolis is from greece. So when he have to call to the USA its very expensive and there also the time differance ;)
Just asking so he can read it tomorrow morining ;)
nope, can't do it via email... cuz the predator will give out certain random codes - which you need to tell the diablo guys, then they give you a "reply code" to enter in the predator which is based on that random generated code, and presto!
but the kicker is, everytime you unplug the predator and plug it back in, that random generated code changes all the time... so, you can't just get the code, email it, get a reply code back, then plug in the predator and enter it... cuz it won't match up, since the predator will generate a new/different random code again when you plug it in and power it back up.
so it has to be done live and in person, over the phone, in real time... with the predator powered up continuously throughout the process in order to keep the codes in sync.
johan
Post by johan »
Well he actually could do it via e-mail or on here, just post up the reset code and leave the predator on that screen until we reply with the pass code.
Diablosport INC
well yeah, there's that :lol: :lol:
if you go that route Manolis - you just have to make sure that the predator is powered up and left turned on the whole time, until they provide you with the pass code to enter into it... you can't turn it off/unplug it from the power adapter until the pass code is entered and the predator gets reset...
otherwise the codes will change and you'll be back to square one...
manolis-1975
Post by manolis-1975 »
thanks guys,i already spoke today with the tech guys and had my predator reset :) tomorrow ill go to my dealer and have the car updated and then try the predator! :) ill keep you informed!
manolis-1975
Ive got news!!!
I updrated the ECM on my dealer and then i pluged the predator in and everything works perfect!!! I did a very small test on the road just to see if the 1st to 4th light goes on but no it doesent!!!!! Later on in the evening i will go for a ride to test the car so i will post my impressions here :)
Thanks all of you guys for all your help and understanding!!
P.S: you have on the predator a tune for 91 octane, why dont you make one for 100 too???? :D
manolis-1975
Also i would like to thank the tech guy who when i called and told him that im from Greece, he asked which part and when i told him Athens he started speaking to me in Greek and told me that he was on Thassos for 5 years!!!! I mean wow, that was awsome!!! Anyway, he guided me through the reset procedure very clear and everything went just fine!!!
CANUCKPREDATOR
Hey Lew, could you help a brother out with a 100 octane tune?
corvette06
Post by corvette06 »
manolis-1975 wrote:Anyone guys????What should i do?? :(
I tried to install the U7194 today and had the same problem as you, I have a 2006 corv. conv. There must be a glitch in the program that will have to be looked at. I wonder if this is happening to anyone else? corvette06 :lamer:
manolis-1975
My friend the problem is solved by getting the car to the dealer and updating the ECM with the latest GM update for the Z06!!!! After that the predator having installed the latest version 08 you will have no problem at all!!!! Read the whole topic and youll get the idea!!!
corvette06
Thanks a bundle :)
manolis-1975
Hallo guys! I just read that theres a new release for the 7194? i have the u7194-9t08nl.crom, the latest as i read is the u7194-9r08.crom right?! should i install it or they are the same? Also should i bring the vehicle to its original backup before updating the predator?
Thanks!
It is the same as what you have.
