Problem with my 7194 and my Z06
CANUCKPREDATOR
Once you do that no need to send us the predator, just call us and get it reset, it can be done over the phone.manolis-1975 wrote:ok, will do tomorrow morning and then try the predator and get back to you!!! Thanks for all your help up to now!!!
Just complain about the battery draining and they will update it for you.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
nope, can't do it via email... cuz the predator will give out certain random codes - which you need to tell the diablo guys, then they give you a "reply code" to enter in the predator which is based on that random generated code, and presto!
but the kicker is, everytime you unplug the predator and plug it back in, that random generated code changes all the time... so, you can't just get the code, email it, get a reply code back, then plug in the predator and enter it... cuz it won't match up, since the predator will generate a new/different random code again when you plug it in and power it back up.
so it has to be done live and in person, over the phone, in real time... with the predator powered up continuously throughout the process in order to keep the codes in sync.
Well he actually could do it via e-mail or on here, just post up the reset code and leave the predator on that screen until we reply with the pass code.
Diablosport INC
Diablosport INC
well yeah, there's that
if you go that route Manolis - you just have to make sure that the predator is powered up and left turned on the whole time, until they provide you with the pass code to enter into it... you can't turn it off/unplug it from the power adapter until the pass code is entered and the predator gets reset...
otherwise the codes will change and you'll be back to square one...
manolis-1975
manolis-1975
Ive got news!!!
I updrated the ECM on my dealer and then i pluged the predator in and everything works perfect!!! I did a very small test on the road just to see if the 1st to 4th light goes on but no it doesent!!!!! Later on in the evening i will go for a ride to test the car so i will post my impressions here
Thanks all of you guys for all your help and understanding!!
P.S: you have on the predator a tune for 91 octane, why dont you make one for 100 too????
manolis-1975
Also i would like to thank the tech guy who when i called and told him that im from Greece, he asked which part and when i told him Athens he started speaking to me in Greek and told me that he was on Thassos for 5 years!!!! I mean wow, that was awsome!!! Anyway, he guided me through the reset procedure very clear and everything went just fine!!!
CANUCKPREDATOR
corvette06
manolis-1975
corvette06 wrote:I tried to install the U7194 today and had the same problem as you, I have a 2006 corv. conv. There must be a glitch in the program that will have to be looked at. I wonder if this is happening to anyone else? corvette06manolis-1975 wrote:Anyone guys????What should i do??
My friend the problem is solved by getting the car to the dealer and updating the ECM with the latest GM update for the Z06!!!! After that the predator having installed the latest version 08 you will have no problem at all!!!! Read the whole topic and youll get the idea!!!
corvette06
manolis-1975 wrote:corvette06 wrote:I tried to install the U7194 today and had the same problem as you, I have a 2006 corv. conv. There must be a glitch in the program that will have to be looked at. I wonder if this is happening to anyone else? corvette06manolis-1975 wrote:Anyone guys????What should i do??
Thanks a bundle
manolis-1975
It is the same as what you have.
