08 ZO6 Custom tune
08 ZO6 Custom tune
Hi
I have the U7194 for 2008 ZO6 & need a custom tune for these mods :
-Kooks LT's with high flow cats.
-Vararam induction.
Having rear O2's light coming on alway's too after the headers install.
Ahmad
-Vararam induction.
Ahmad
RE: 08 ZO6 Custom tune
You will need to post your current tune and the backup file for it to be modified into a custom tune.
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
yeah, all you need is a custom tune to disable the codes... nothing to do for the vararam intake - you need to adjust your fueling yourself for that...
you need to do some normal steady driving/cruising data logs to see where your average LTFT's are at and then adjust your injector slope accordingly...
here's info:
here's info:
which tune file is that that you posted?? is it the orignal backup or is it the copy of the diablo tune outta your car??
you need to copy the current diablo tune outta your car and post up that file... here's info on how to do that:
http://diablosport.com/index.php?name=P ... pic&t=6547
what revision is your predator on?? first time I've ever heard of an 08 vette predator not having the modify tune option...
you would select the same tune you previously installed, and then you get to another menu that has Install Tune or Modify Tune...
update your 7194 predator to a newer revision...
http://diablosport.com/downloads/predat ... -9r07.crom
make sure you restore your original backup to your car first, before you update the predator.
