U7194 update, again...
RE: Thanks
Sweetness....
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
RE: Thanks
You are still the MAN. Thanks for your hard work.
RE: Thanks
Johan
As I mentioned above, I installed the new update yesterday with no problem (thank you). Today (after 100 miles or so), I tried to do a data log per GrumpyAeroguy's instructions. Once I set the data log parameters (GM short, 8 different parameters ) dorve for 15 mintutes on highway then hit escape as instructed, it asked if I wanted to read and record data (yes/no). I chose yes but it only read/displayed the data, and did not record it (at least not that I could tell. It did not ask if I wanted to log data like it did with old crom and there wasnt a 0-100% progress bar. If I manually chose the data logging option on the diagnostic menu, I get a "ECKS fatal error" message and the unit says "You may now unplug predator". I guess what I am trying to say is that I cant log the data like I did before. Is there a different procedure wih the 9t08p update? Any ideas here?
therink
2012 Silverado 3500 HD LTZ, Z71, crew cab, 4:10, 6.5 box, Stock 6.0, K&N drop in
RE: Thanks
still not working for me
cal id pcm:
12630501(main os)
12626751(system)
12626741(fuel system)
12626793
(speedometer)
12626699(engine diagnostic)
12631165(engine operation)
12625892(slave operating system)
12626692(engine)
cal id pcm:
12630501(main os)
12626751(system)
12626793
(speedometer)
12626692(engine)
09 silverado 5.3 flexfuel 4l65e flowmaster cai ds tuner
Re: RE: Thanks
Did you let it take a backup with the new update?bbnova wrote:still not working for me
cal id pcm:
12630501(main os)
12626751(system)
12626793
(speedometer)
12626692(engine)
In order to be able to support you i will need a backup from you, or you can also post or pm me your vin and i can see if i can get the file from a bench flash.
Diablosport INC
Diablosport INC
Re: RE: Thanks
We fixed some datalog and dtc checks on the "q" version, is this what you used?therink wrote:Johan
Diablosport INC
Diablosport INC
RE: Re: RE: Thanks
i just udated to the q crom but still when i turn the speed limiter off i get those abs and brake lights other than that everything is perfect the updated tune has some nice power.
2007 gmc seria 6.0L VMAX S@Gcold air intake gibson cat back daul exaust diablo performance tune
Re: RE: Re: RE: Thanks
Hmm, do you think you can e-mail me your original backup and last tune written so i can look at it please?podrup42 wrote:i just udated to the q crom but still when i turn the speed limiter off i get those abs and brake lights other than that everything is perfect the updated tune has some nice power.
Diablosport INC
Diablosport INC
RE: Re: RE: Re: RE: Thanks
ye no problem when i get home from work i will send u the files
No, I used the "p" version. I will install the q and give it another shot.
therink
Q is the latest one...
http://www.diablosport.com/downloads/pr ... 9t08q.crom
yes it should work with your 08 truck...
the tunes are different from the 05a revision, so yes it's worth the update for you...
