In short, air intake, exhaust, fuel system (Walbro), Predator, and Extreme Puck.
2wd, Q/C, auto, 2003 Dodge
In Phoenix, Firebird Raceway, 100+F deg!! It was a HOT night.
Best time 14.11 @ 99.5mph. I really think if it was a little cooler (90deg) and I got a good launch, 13's would of been it! I was stoked for basically a predator/puck!
Bad news.. EGTs were 1650 at the end of the track. Best time came with the extreme puff toon. Tried rkl puff (no timing) and got 14.5's. EGTs with rkl were actually 100deg lower, 60ft was a little better, but it seemed to peter off on top.
Fuel pressure was solid the whole time..
I was impressed, but curious about the slower rkl times? Little to no wheel spin.
Finally! To the Track!
RE: Finally! To the Track!
What was your rail pressure?
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
Good q... I don't know. Probably draining rail, and I suspect my rail pressure valve is ill. I do have a new valve and I need to get it in.
Re: RE: Finally! To the Track!
or you could cap it...5point9 wrote:Good q... I don't know. Probably draining rail, and I suspect my rail pressure valve is ill. I do have a new valve and I need to get it in.
RE: Re: RE: Finally! To the Track!
Pretty impressive for sure!
