New to predator any suggestions?
jagstallion
I have a 2007 mustang gt . I just added flowmasters, and xpipe and a bbk cold air intake. I just bought a diablo predator(u7145) and I was wondering if anybody had any suggestions for changing the parameters to give my car the most hp and torque. Thanks for your help!
RE: New to predator any suggestions?
No adjustment needed for the flowmasters. The xpipe you installed on the car. Does it have cats? As for the BBK CAI. Just go into the MAF curve and add anywhere from 5-10% until the check engine light goes out. Add in small increments. Add 5 first if it needs more add 7 next.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
Diablosport Inc.
Tech Support
jagstallion
No cats on my xpipe. I'm smelling alot of exhaust too whenever my car is in idle. Is their anything I can do with the predator or do I have to put my cats back on?Phil wrote:No adjustment needed for the flowmasters. The xpipe you installed on the car. Does it have cats? As for the BBK CAI. Just go into the MAF curve and add anywhere from 5-10% until the check engine light goes out. Add in small increments. Add 5 first if it needs more add 7 next.
smelly exhaust is because you removed your cats.
jagstallion
The smelly exhaust is pollution. That is what the cats clean up. It is not tune related in my opinion. Every mustang I have owned and removed cats from (1987-2006) has a smelly exhaust when you remove the cats, even after retuning.
The smell of the exhaust is most evident at idle like at stoplights. You could smell it on my clothes if I drove around with the windows down cruising the downtown. That is just par for the course when you remove your cats.
jagstallion
Yeah that's what I figured. I guess I was just hoping their was some kind of paramater I could change so it doesn't run to lean. Well thanks guys for your help
