U7194 update, again...
blubottle
Vehicle not recognized...
Post by blubottle »
09 yukon xl was running 9r07 fine. Attempted 9t08q crom = "vehicle not recognized..."
my VIN 1GKFK36309R204219
thanks...
johan
Re: Vehicle not recognized...
Post by johan »
blubottle wrote:09 yukon xl was running 9r07 fine. Attempted 9t08q crom = "vehicle not recognized..."
thanks...
Did you try to continue and let it take a backup?
If you do this and e-mail me your backup, support for it will be added in very quick.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
johan
Post by johan »
kfc wrote:So can we expect a 9t09 update next week with TCM support?
It's nice to dream :P
Wont be that soon but TCM support is being worked upon and has a high priority.
Diablosport INC
JJ406
Post by JJ406 »
I received the 7194 about 6 weeks ago and connected it to my 2009 Avalanche with 6.0L engine. It did not recognize my truck but it did store a back up file so I decided to keep it and wait for a new tune. I have downloaded the latest tune to the Predator, but I have never connected it back to my truck since the very first time (I have been out of town). Last week (on the way to a job interview of course) after driving a couple hundred miles without porblems since I had initially plugged in the Predator my truck went haywire with the check engine light coming on, and the service stabilitrack, service suspension, service trailer brake assist, and it was stuck in first gear. I disconnected the battery and then restarted it after which it ran fine for about 5 miles before it did the same thing again. After swapping vehicles with my wife, she took it to the dealer, they reflashed it, and I have driven another 150 miles without problems. I will probably just send the Predator back because I certainly don't want this to happen again, but does anybody have any idea what the issue could be? Thanks.
blubottle
Post by blubottle »
thanks...
Hi Johan thanks for taking time...Here is the scoop...
What I did was reflashed ECM back to original. Upgraded new DSDL. Downloaded 9t08q crom.
Then I get "Your calibration is not supported..."
PCM:
12630501 (main os)
12626756 (system)
12633984 (fuel system)
12626771 (speedometer)
12634000 (engine diagnostic)
12631173 (engine operation)
12625892 (Slave Operating System)
12626693 (engine)
It wont let me backup also....
Im mostly interested in the 87 tune since I drive the truck 80 miles a day. So is there any significant change from the previous 9r07 crom?
Thanks again for your time and effort.
sk65stang
Re: RE: Re: RE: Thanks
Post by sk65stang »
podrup42 wrote:i just udated to the q crom but still when i turn the speed limiter off i get those abs and brake lights other than that everything is perfect the updated tune has some nice power.
I am still getting the ABS/Brake light regardless of tune or tire size changes as well ... I included the original backup and last tune written any ideas?
original backup.grg
(54.85 KiB) Downloaded 166 times
87custom_tune.grg
(2.25 KiB) Downloaded 221 times
07 Silverado Z71 4x4
5.3 Diablo, K&N CAI
rjaro7
RE: Re: RE: Re: RE: Thanks
Post by rjaro7 »
how do you run a log with 9t08q. after selecting the parameters ,i select watch and record now but its not recording anything
2010 GMC Sierra 5.3 Flex
johan
Post by johan »
Please shoot me an e-mail and i will send you back a modified file to test.
E-mail in sig...
Diablosport INC
08Silverado
Post by 08Silverado »
Updated to the q crom, now it doesnt work on my truck. Also wont let me do a backup so what do you need from me in order for my truck to be supported.
08 Silverado 4.8l,K&N drop in, Airraid M.I.T,Magnaflow muffler, Vette servo,Predator 93 tune
it should let you do the backup...
what errors and/or messages does it give on the screen when you try to install a tune??
08Silverado
Says i'm not supported, do you want to try to do the backup, I continued and it didnt do the backup
johan
Post by johan »
Did you pick modify stock tune? It will take a backup once you pick that.
If it does not then it should spit out some sort of error message, if you could post up what it says we can try to help you out, also if you want to post your vin number as well i can replicate it here on the bench.
Diablosport INC
08Silverado
Ok, have it posted in 20 min
08Silverado
Ok my vin is 1gcec14c68z143503. It backed up my stock tune also have that posted shortly.
johan
Post by johan »
Ok great, post or e-mail me your backup and we will get you added in quickly.
Diablosport INC
Return to “Predator GM Gas”
