Question on Quick Adjust
dco
Post by dco »
I am confused. :? I have loaded the Diablo tune on my 2006 Charger. I see that there is a quick adjust menu where I can change firmness of the shifting and adjust for tire size but when I went into that menu, it said if I want Diablo tunes and quick adjust perameters to go back to Diablo tunes and select. Well, I have already done that, so is there a need to do any Quick Adjust as well? I just want to make sure the shift firmness is firm and when I loaded the Diablo tune, it didn't ask for tire size. Is there a way to do that? Or did I need to go farther into the menu? I didn't want to start downloading a tune again and mess something up. :oops:
RE: Question on Quick Adjust
Shift firmness is separate from the tune.
If you already have the tune installed, you can simply go into QA and make any changes you want.
broadfca
Re: Question on Quick Adjust
Post by broadfca »
dco wrote:I am confused. :? I have loaded the Diablo tune on my 2006 Charger. I see that there is a quick adjust menu where I can change firmness of the shifting and adjust for tire size but when I went into that menu, it said if I want Diablo tunes and quick adjust perameters to go back to Diablo tunes and select. Well, I have already done that, so is there a need to do any Quick Adjust as well? I just want to make sure the shift firmness is firm and when I loaded the Diablo tune, it didn't ask for tire size. Is there a way to do that? Or did I need to go farther into the menu? I didn't want to start downloading a tune again and mess something up. :oops:
First off, when you use the "Quick Adjust" it will only change the items you specify in the "Quick Adjust" menu, nothing else will be changed. It will not change your tune or mess anything up. So, just go to quick adjust , tell it what you want it to do...relax and enjoy.
To change the tune you have already installed, you have to go to the adjust parameters in your selected tune and change it there. Otherwise the predator will never change or download a tune other than the one you originally selected.
Hope this helps
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
dco
RE: Re: Question on Quick Adjust
Post by dco »
OK, thanks.
Tom in Walla Walla, WA
2010 B5 Blue Challenger R/T Classic 6 spd
