Still getting trouble codes
Mineral_GT
Post by Mineral_GT »
There Baaaack!!!! I'm getting obd II codes P0172 & P0175 ( running too rich, bank 1 and 2 respectively. I'm using the Steeda CAI 91 octane tune Ver. 8r37 on my U7140 tuner. I've cleaned my MAF sensor (again), I'll reset the codes, but they come back. The check engine light w/ the above codes, usually comes on when firing up the car, but sometimes comes on during hard excelleration. The problem seemed to be sporadic before, but now is happening all the time. HELP!!!
P.S. No problems with stock tune in car.
Car mods in Sig.
Scott
Mineral Grey 2005 Mustang GT 5Spd. Red Leather Int.
Steeda Lowering Springs
Steeda CAI
Steeda Axle Back Exhaust
BBk Throttle Body
UDP
GT500 Wheels
kmac1
Re: Still getting trouble codes
Post by kmac1 »
Mineral_GT wrote:There Baaaack!!!! I'm getting obd II codes P0172 & P0175 ( running too rich, bank 1 and 2 respectively. I'm using the Steeda CAI 91 octane tune Ver. 8r37 on my U7140 tuner. I've cleaned my MAF sensor (again), I'll reset the codes, but they come back. The check engine light w/ the above codes, usually comes on when firing up the car, but sometimes comes on during hard excelleration. The problem seemed to be sporadic before, but now is happening all the time. HELP!!!
Car mods in Sig.
Scott
Scott, What is your location? You wouldn't happen to be close to Delray Beach FL would you?
Kevin@DiabloSport
Mineral_GT
I'm in Vancouver BC Canada
No where near Fla.
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
kmac1
Re: I'm in Vancouver BC Canada
Post by kmac1 »
Mineral_GT wrote:No where near Fla.
Your mods sound very straight forward. You wouldn't be running the racer tune would you? That will cause your issues. If not, please get me your calid and I'll take a look at the tune in that rev and see if there is an issue.
Kevin@DiabloSport
Mineral_GT
Cal ID
Hi Mike,
Here's the Cal ID FBJR3G5
Hope this helps.
I'm scheduled for a dyno tune on Thurs. to try and resolve this issue. But i much rather not have to do that at this time and put that money towards some 4:10's, then the dyno!!
scott
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
Mineral_GT
RE: Cal ID
Sorry Kevin, I didn't mean to call you Mike.. :oops:
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
kmac1
Re: Cal ID
Post by kmac1 »
Mineral_GT wrote:Hi Mike,
Hope this helps.
scott
That tune looks ok. Are you running the racer tune with the street kit?
Kevin@DiabloSport
Mineral_GT
RE: Re: Cal ID
[quote="kmac1"][quote="Mineral_GT"]Hi Mike,
HereI'm running the 91 octane steeda tune. I haven't seen anything called a racer tune. Should I look somewhere for that? FYI " last tune written - Steeda 91 Octane the
The one I installed is under the "OEM select Menu"
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
kmac1
Re: RE: Re: Cal ID
Post by kmac1 »
Sorry, my bad! I am thinking one thing and typing the other. There were 2 Steeda cold air kits once upon a time. Your's wouldn't happen to be an 85mm maf housing would it? If your cai is fairly new then it is likely the correct one. It should be 90mm. It sounds like there may be an issue with the car.
The racer is a C&L intake, I don't know why I went off on that path!
Kevin@DiabloSport
Mineral_GT
RE: Re: RE: Re: Cal ID
Oh that's a GOOD question!!!! I've had the car for a few months. All the current mods were on the car and the predator came with the car. BUT the car had the stock tune in it.
I'm gonna measure the housing. If it is 85 mm, is there an adjustment I can make? Or am I buying a new CAI?? If I'm buying one, would you recommed one over another?
Hey by the way, thanks for all the help so far!!
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
Mineral_GT
You know what.. the inside diameter measures 80 mm, can this be right??
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
Return to “Predator Ford Gas”
