Still poor mileage
MAtSTER
RE: Still poor mileage
My boost runs around 35 when towing up hill, around 15 on flat. 10 is the lowest reading I've seen under any acceleration.
I would think its your egr valve MAtSTER. Sound a lot like the troubles i have been having, finally getting my truck in to switch it out!!!
Hoondog here,
Yes, I am still getting 16-17 mpg out of my completely stock 08' 6.4 driving with a light foot at 65-71 mph using the tow tune with cruise control as much as possible. I hauled 10,000 lbs a couple weeks ago in tow tune and dropped down to 15 mpg at 70 mph. I live in central wa state where the climate is warm and the air is dry. Note that I was only getting 11.4 mpg after the ford reflash. Can't thank Don enough for the work on getting these fords to run like they should have from the factory.....
Hoondog
Hoondog
i have another truck coming in here today. This truck has a spartan system on it, no dpf, intake and a built tranny. I offered him some dyno time in exchange for taking a look at look @ the spartan tunes. I will post up some results today.
Don
2002 WS6
2002 WS6
let us know if you find out about the intake codes.
I have heard of guys with the spartan tuning putting down 550hp and 1200tq or more. Guess the tunes are just crazy!! Super costly thou!!!
Ok so this truck was harley davidson addition 6.4L f250 with air raid intake, dpf delete (still retained the cat) and a built transmission. Stock it did 300/600...no different then a stock 6.4L..very interesting. I will post the number on monday as i cant remember what tunes did what. I tested motor city diesel tunes, and spartan tunes. The Spartan's i remember got good hp but torque only was around 1000 for the best run. I was expecting a little more. I got to test a street and race verison of the motor city and a V4 version of spartan's 275 tune.I noticed that torque is virtually unaffected by the dpf, but hp takes a big jump when deleted. As my tunes made 440/900, one of the tunes made 500/900. probably b/c it could tolerate more timing. Truck goes 13.4 @ 100mph on the street motor city tune, i remember the race picked up another 50hp/100 ftlbs so i would assume he is in the 12's now. No codes with the air raid intake.
Don
2002 WS6
2002 WS6
was the lack of airaid intake codes tune related?
Not sure, we did dyno it stock and got no codes, but it was onlyfor a few wot runs over a few minutes so i doubt they would have even showed up. Im real interested to see the l30 based tunes and see how the calibration is diff v.s. the l20. I did a comparison of the old cal's vs the new ones and didnt see anything that really stood out that might cause the codes. I still need to do some digging though..
Don
2002 WS6
2002 WS6
MAtSTER
I have been keeping a close eye on the boost. While cruising on hwy. it's 10 psi. or less... when I accelerate to pass or going up hill it's 20-30 psi... while towing at cruising speeds it's 20-25 psi... while under acceleration (still towing) it's 35-40. Can I safely tow around 7,000 lbs. in the 80 h.p. tune? I seem to get a little better mpg (less than 1 mpg) went from 9.3 to 9.9. Was using the 50 h.p. / economy tune.
