cole
programmer can't read vehicle id how can I correct this??
unable to read vehicle id msg....
jackgf250hdsd
2007 F-250 Harley Davidson 4x4 CC
Magnaflow 4" turbo back (cat delete) 5" tip,
Afe stage 2/with pro-gaurd 7/pre-filter,
acufab intake elbow, limo tint all around, 8" on windshield, zoodad mod,
100hp tune...
100hp tune...
jackgf250hdsd
RE: unable to read vehicle id msg....
cole,
msg also says that it does not match last tune (c9a871a6:7c1598d2)
100hp tune...
100hp tune...
Re: RE: unable to read vehicle id msg....
Make sure a copy of the orginal backup is stored on the PC first and then make sure that the DS Downloader software has Compress Send button checked. Then send the custom tune to the predator. IT will work after you do that.jackgf250hdsd wrote:cole,
The instructions are here http://diablosport.com/downloads/predat ... ctions.doc
Cole Stevens
jackgf250hdsd
RE: Re: RE: unable to read vehicle id msg....
Cole
can't upload backup, have followed all inst. but the programmer is asking for the ignition to be turned off??
100hp tune...
100hp tune...
jackgf250hdsd
Cole,
here is the calid vxcf4s3
100hp tune...
100hp tune...
Re: RE: Re: RE: unable to read vehicle id msg....
May i ask is this r14 revision? This has been tested in r17 and has not shown up. But if it ask you this message after sending to the predator disregard it and go to the truck and plug it in and hit performance tune. You should see Diablo Tunes and Custom tunes.. Under Custom tunes will be the custom tune that you sent it. weird thing is that on the older software there was a bug on custom tune transfer. The file would transfer but it gave that stupid message.jackgf250hdsd wrote:Cole,
Cole Stevens
jackgf250hdsd
RE: Re: RE: Re: RE: unable to read vehicle id msg....
Cole,
I'm running r17, I tried searching for the custom tune but not there, I tried downloading it twice and both times it gave an ok msg. but still not there. I can't load backup due to ignition on msg..
100hp tune...
100hp tune...
