2009 Chrysler 300C 5.7 68061222AA Cal id not supported
jimmyc8000
Post by jimmyc8000 »
concoursd wrote:jimmy,
68061222AA is already obsolete and chrysler has released 68061222AB to replace it. So, DiabloSport will be supporting the AB version because it is the most current calibration. The predator will be able to update your cars calibration prior to installing the diablo tunes with the new revision coming out. This is the madness of OEM calibration updates. You would think Chrysler would get them right before releasing them as they are the OEM but that is not the case.
Thanks for the info, I think I understand what you are saying and it makes sense. I really don't know why Chrysler would keep updating their own firmware unless their is some sort of bug or flaw in their programming, its nuts. I will hold tight and let let these boys work their magic as the season here in upstate NY will be a changing and the 300 will go into hibernation for the winter
pbgear
Post by pbgear »
"300 will go into hibernation for the winter"
hopefully we'll have the update by next spring
Cruisin1966
Post by Cruisin1966 »
jimmyc8000 wrote: Thanks for the info, I think I understand what you are saying and it makes sense. I really don't know why Chrysler would keep updating their own firmware unless their is some sort of bug or flaw in their programming, its nuts. I will hold tight and let let these boys work their magic as the season here in upstate NY will be a changing and the 300 will go into hibernation for the winter
Exactly. They are either enhancements they wanted in the programming that they didn't get in in time and/or bug fixes for what's there now. Nothing is ever perfect the first time. Trust me. I'm a software developer, and you can spend your whole life trying to make something perfect before it's released. Al that will get you is something that never gets released. It's quite complex, and I can understand little flaws (none that would actually stop the car from working hopefully) being released, and enhancements being wanted to make the vehicles run better. Not even so the average driver would ever notice, just perhaps for longevity or reliability
2007 Sublime Daytona #082/150
McKinney catch can (to be installed)
johan
Post by johan »
I will most likely post up a beta crom for these new calids here shortly, stay tooned....
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
aboz3
Post by aboz3 »
So, really when should we expect a revision / fix???? Will you refund???
aboz3 wrote:So, really when should we expect a revision / fix???? Will you refund???
Did you check the link posted right above you where the update has been posted for a week or so?
