to much fuel from chip!?
jimmiee
Post by jimmiee »
I just recently purchased my predator tuner and have installed the 100hp tune on my 2002 7.3l f250. My only complaint is that it is overfueling the engine... alot in my opinion. when im full throttle the engine even sounds like its way to rich. if i let off to about half throttle it feels faster and most definatly accelerates faster! If i can i would like to leave the chip as is and improve other aspects of the engine to utilize this extra fuel, any suggestions would be great. The engine makes about 26psi of boost at full throttle, egt guage reads 1560* F and will keep climbing if i do not let off. Is this normal for the chip to be running to rich? can i modify the chip to run less fuel without steping down to the 85hp setting? I have a 4" open exhaust from the turbo back, aem brute force intake, wicked wheel impellor, 100hp setting currently installed on my truck.
jimmiee
Post by jimmiee »
PS: my tuner number is u7170.
cole
Post by cole »
jimmiee wrote:PS: my tuner number is u7170.
Can you get me the calibration id of your truck pls. OPTIONS/TROUBLESHOOTING/SHOWCALID
Cole Stevens
Richd1963
Post by Richd1963 »
:shock: "EGT 1560 F" would be my concern. Isn't that a little high? :shock:
My temps used to run around 800-950F normal driving and 1000-1100F under medium load such as uphill driving with 100hp tune. I never let it go above 1200F.
Good luck
Richard
2004 F250 6.0 4X4, 6" Skyjacker softride all spring lift, BFG 35" on 17's, Rancho 9000's, K&N cold air intake, MBRP Stainless turbo back w/cat delete pipe installed. Diprocal triple pillar gages, Superlift truespeed sensor, fumatomo valve.
cole
Post by cole »
Richd1963 wrote::shock: "EGT 1560 F" would be my concern. Isn't that a little high? :shock:
Good luck
Anyone who has an issue with their tunes please post your calibration ID.
Cole Stevens
jimmiee
Post by jimmiee »
cal id is TNAA4N2
cole
Post by cole »
Cole Stevens
jimmiee
Post by jimmiee »
do i load this as a custom tune?
Gas to fill up your truck: $75
Slurpy: $3
Spinning the tires and getting sideways coming out of the gas station while towing your 33' Weekend Warrior... PRICELESS
Yes.
jimmiee
Post by jimmiee »
ok... can you give me some instructions on how to load it into the predator? i already downloaded the ds downloader... whats next?
Slurpy: $3
jimmiee
Post by jimmiee »
its not working for me. everytime i import the tune in it gives me an import failed? what am i doing wrong, do i have to return the truck back to stock before i import any custom tunes?
Slurpy: $3
jimmiee
Post by jimmiee »
diablo sport can you shed some light on this situation? i cant import the tune into the predator.
Slurpy: $3
