Hi from Germany,
I have the U7130, ~1,5 years old, without speedlimiter adjust.
The only authorized Diablosport dealer in Germany has downloaded
on my Predator the last update 9r05.
I hoped, now I can adjust the speed limiter.
But there is no tune to do it ?
Who can help me ?
Thank you,
Oliver
U7130 last update, but no speedlimiter adjust ...
MrTurbodiesel
RE: U7130 last update, but no speedlimiter adjust ...
The U7130 does not yet have this ability.
MrTurbodiesel
No chance ?
That was your answer at April,22. this year :
Starting with revision 9r03 the speed limiter can be raised in the modify tune menu.
My bad, was not thinking clearly...
If you go to the modify tune menu, and disable the limiter, then reinstall the tune, it will turn it off.
Are you saying you dont see the option, or you see it but it does not work?
MrTurbodiesel
No problem...
But...I have no option "modify tune"...
So, after you select the tune, you get a screen that says:
Install Tune
But it does not say 'Modify Tune' underneath Install tune??
Install Tune
MrTurbodiesel
I have only this 4 main menus:
- Performance Tune
-Diagnostics
-Options
-Tool Info
- Performance Tune
-Diagnostics
-Options
-Tool Info
No, you are not following...
You go to performance tune, select the tune you want, then the tool will say:
Install Tune
Modify tune
Select modify tune, then select modify parameters, go to speed limiter, set it to off, then press escape until the tool asks if you would like to install the tune, choose yes.
Install Tune
Modify tune
MrTurbodiesel
Oh God...that was a long way.
THANK YOU Mikel, I have found it !!!
That is the advantage, to take the Predator from Diablosport !!
They have a great customer service !!
Thank you from Germany.
(Now it's 10:15 pm here in Germany, time to go to bed)
Goodnight.
