I had an 09 Challenger R/T in the shop today and discovered on our dyno that the VE tables do not work in the software (they are there, but when changes are made the car does not respond) Luckily i needed a global fuel change, so I scaled the injectors until we get this figured out.
Any ideas?
Eric
2009 Challenger - VE not working
- ipsmotorsports
- Original.drg
- Pulled file
- (88.15 KiB) Downloaded 376 times
RE: 2009 Challenger - VE not working
I have not seen this, how did you verify that the ve tables did not work?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
- ipsmotorsports
I made a 20% change in the WOT cells and nothing changed. The only way to change fueling in the car was an injector scaling.
Eric
Eric
Did you make sure to increase the max ve scalar, i think it is at 1.15 stock so it will clip any value higher than that to 1.15.
Diablosport INC
Diablosport INC
- ipsmotorsports
I'm showing 0.87 max VE stock, I did think of this though.... has me baffled
any answers to this. I'm having the same issue..
- latemodelracecraft
Yes I am having the sam issues
