Predator Puck combo, just what exactly is each doing?
- ranger_dog
It is my understanding that the Puck is a pressure box that increases the rail pressure of the fuel delivery, correct? Does it do anything else? The Predator alone can increase the rail pressure, correct? It also adjusts the timing too I think, correct? Does it do anything else (not talking about the special feature, like tire size adjust, idle up, etc.) Then I am also correct in thinking that when using the Predator with the Puck and installing a stacked tune, the difference in those tunes are they remove the increase in the fuel pressure since the puck is doing that? So in essence, running the stacked tunes in the Predator and the Puck together is really only a benefit because you can adjust the pressure of the fuel delivery from stock, 60, and 90 HP settings on the fly (or without needing to download a new tune) and essentially it also makes each tune into 3 tunes with that switch. Do I understand the functioning correctly on these units? Last question, which switch position will give you the closest match when comparing running stacked tunes with a puck with unstacked tunes and the predator alone?
Thanks, Ed 06 2500 QC 4x4 CTD, Auto, 3.73's, 275/70/18's, Thuren/Carli/Bilstein susp mods, 4 inch duals, K&N Filter, Modified intake, Predator & Puck, Quadzilla Cmdr & boost fooler, more to come.
RE: Predator Puck combo, just what exactly is each doing?
You hit the nail onthe head.
Cant really answer the switch position question, as I have not monitored all of the pressures in all of the different combos.
don't forget to add that new tranny to your signature...
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
- ranger_dog
Re: RE: Predator Puck combo, just what exactly is each doing
Somedayropnjessi wrote:don't forget to add that new tranny to your signature...
The thing about upgrading the tranny is being able to use the full potential of these types of modifications and have the capability of expanding to even more horsepower as it is very addictive. I used to say "yeah I'll be easy on the tranny and just run the low tunes"....NOT... I finally broke the tranny....LOLranger_dog wrote:Somedayropnjessi wrote:don't forget to add that new tranny to your signature...Holding out on one for a little while and holding up on the heavy foot to keep the stock one in good shape. I am still waiting for someone to offer a foolproof conversion to the 68RFE so I can take advantage of the 6 speed. Once they have one, and Goerend Brothers starts to improve them, I am getting one.
Dodgezilla
RE: Re: RE: Predator Puck combo, just what exactly is each d
LOL!!! That's what I am saying right now too.......
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
masonsmustangs
any problems with standards?
mostly with the clutches, stock ones don't do to well for long
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
