Gas Question on Spark Advance adjustments ?
how can i adjustment spark ?
RE: Gas Question on Spark Advance adjustments ?
can anyone tell ,e how can i adjust the spark
SandMan817
go under "modify parameters" and go to the "SPARK" selection and then you can adjust from there.
2002 GMC Sierra Ext Cab 5.3(LM7)
I mean how can I adjust rightly like more (+) or less (-)
SandMan817
im pretty sure, to the right is more spark, and to the left is less spark. Somebody please correct me if i am wrong.
I mean how can I adjust rightly there any analyze program or in which rate must be
If you are not sure of what to change, you should not be changing the timing....
can you tell me how can i change rightly there are any thing can help me like program or doc
SandMan817
the Diablosport DataViewer program is great for analyzing your log files, if you understand what you are looking at. Also, check out DsLogReDux, it is an amazing program that automaticly goes over your log file and tells you how much to adjust your LTFT's.
Have you followed monte's tutorial?
http://www.diablosport.com/index.php?na ... opic&t=917
fadhil - There is no guide or document on how to adjust it. When you adjust spark from the tool, it adjusts to a curve. The only RIGHT, PROPER way to adjust spark is to have your vehicle run on a chassis dynamometer. The technician who does the programming will know how to properly set the timing to gain the maximum amount of power for your vehicle.
Unless you know what you are doing, or are willing to risk severe engine damage to your vehicle, do not adjust the timing advance.
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
Well said, Neon...
