No worky code 68061222aa
U 7135 reviision r18 2009 Chrysler 300C 5.7 hemi
Just received the unit was going to the strip tomorrow night directly after work...hooked up unit and it told me it does not support 68061222aa. WTH???? Uploaded latest revision....no luck...this is BS
RE: No worky code 68061222aa
There is an update posted here for the past several days to add support for your car.
It is in the stickies.
I see you posted about this twice, fwiw, had you searched it real quick, you'd have found the answer without any need to post.
Mike
Mike
I down loaded your latest version 19g and it still won't work. What should I do next?
what happened?
what was the exact message it gave you?
Thanks for the quick response. I believe that it said I 68061222aa needs updated, but I cannot remember for sure. I am at work, and have the info at home, so I will have to send exact message tonight. I got the car to run 14.008 of Friday night with only cold air and driving technique, so can wait to change the tune.
Re: RE: No worky code 68061222aa
This can be updated using the dsdownloader through our website.aboz3 wrote:Thanks for the quick response. I believe that it said I 68061222aa needs updated, but I cannot remember for sure. I am at work, and have the info at home, so I will have to send exact message tonight. I got the car to run 14.008 of Friday night with only cold air and driving technique, so can wait to change the tune.
RE: Re: RE: No worky code 68061222aa
So, I can flash 68061224AB and get the info on the dsdownloader? Are there instructions to be found on how to do this? Sorry about the ignorance, but I am just getting into the loop on modifying the new computer cars.
- fordomatic69
Follow these instructions to the letter:
http://www.diablosport.com/index.php?mo ... ay&pid=117
You'll need the power supply and usb-serial cable as well.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
Re: RE: Re: RE: No worky code 68061222aa
68061222ABaboz3 wrote:So, I can flash 68061224AB and get the info on the dsdownloader? Are there instructions to be found on how to do this? Sorry about the ignorance, but I am just getting into the loop on modifying the new computer cars.
RE: Re: RE: Re: RE: No worky code 68061222aa
Thanks seabass..I punched in the wrong number. All of the above worked and I installed the 93 cai tune. Took the car out for initial drive an it seems to surge while cruising 25 - 50 MPH. Will it take a fw cycles to smooth out?
do you have MDS still enabled?
Yes, the MDS is still enabled.
Re: RE: Re: RE: Re: RE: No worky code 68061222aa
Then no, it won't smooth out in a couple of cyclesaboz3 wrote:Yes, the MDS is still enabled.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
