u7194 No parameter adjustments on 2008 Z06?
After installing the tune it will not allow me to modify the tune.
Say this type of vehicle and trans will not allow adjustments.
Also doesnt allow you to choose between header tune and stock diablo tune like before?
thanks keith
thanks keith
RE: u7194 No parameter adjustments on 2008 Z06?
Could you post your vin.
Did you select manual transmission? If you selected auto trans it is possible they wont show.
The latest rev with 08 support have all the long tube tunes removed due to EPA restrictions.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
I have restored original tune then reistalled diablo tune still can"t modify parameters. vehicle/trans type (2)
vin#1G1YY26E885108898
CALID#IE3B02E43A420400C
THANKS KEITH
THANKS KEITH
Re: u7194 No parameter adjustments on 2008 Z06?
I have exactly the same problem!!! Please help me...suprjet wrote:After installing the tune it will not allow me to modify the tune.
thanks keith
RE: Re: u7194 No parameter adjustments on 2008 Z06?
Same thing here 08 Export ZO6.
Ahmad
Ahmad
We're looking into it.
and make sure it's updated to the latest revision...
and yeah, what gump said... you have to restore your original backup stock tune to your 06 first in order to unlock the predator, and then you could use it on your 08...
but you can not tune both cars at the same time...
try the latest 7194 revision update that was posted the other day...
