can anyone help
jrg5411
can anyone help
Post by jrg5411 »
when i click on the send crom fiile to predator after a few seconds i get a pop up that says file download failed
ski
Post by ski »
If you're using a serial-to-USB adapter to connect the Predator to your computer, then that may be the cause. If possible, d/l the update on a computer with a serial port, and then upload it to the Predator.
If the above is not the case, then make sure the COM port that's being used in D/SDownloader is enabled in BIOS on the computer, and it does not have any problems in Device Manager.
If that's ok, then make sure 115,200 baud rate is being used on both D/SDownloader and in the COM port's settings.
If no luck, then try 57,600 baud rate for both.
MustangChris04
Post by MustangChris04 »
Im having the same problem, on the predator it stops after 5120 bytes and then on the computer it says failed after packet 12. I cant seem to get it to work, I tried settings both to 115,200 and 57,600 and no luck.
I got it to download the original and it said success on the computer but on the predator it was still at 0 bytes and the file I got was .frg which was only 1024 bytes.
LightningMike03
Post by LightningMike03 »
Is the compressed send button checked at the top of the DSDownloader?
If so uncheck and try again.
Guys, we need some info here....what part number are you trying to update, what revision are you applying, what cable are you using to do the updates....etc.
MustangChris04
Radioshack db9 to usb cable. I am just trying to pull a tune off of it so I can make adjustments on the computer.
Return to “Predator Ford Gas”
