2000 7.3 Knocks on 110 tune
lander
Post by lander »
My predator is 7000 I got it form The Shop hear in Lincoln Ne . It has a 9r04 update Pat said this is a 30 psi tune My truck is a 2000 f350 7.3 4 inch exhaust, afe cold air intake and wiser wheel ats 1.00 exhaust housing , big head wast gate . I have been running the 85 hp tune no problems, I tried to run the 110 yesterday and at around 19 psi is makes a knocking noise like a fuel knock I have know noise to 25psi on the 85 hp tune any suggestions thanks lance
jbeasts10
RE: 2000 7.3 Knocks on 110 tune
Post by jbeasts10 »
Knock is normal..it is timing related.Mine does it also..No need to worry.You should be seeing roughly 28 to 32 lbs with that tune and your set-up.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
lander
Post by lander »
Do you need a boost-fooler to get those boost number, and what did you do for your tranny
2000 psd banks wheel ats 1.00 exhaust housing , 4" exhaust, afe intake , air dog fuel system.
jbeasts10
Post by jbeasts10 »
Yes ,I have a boost fooler.(I made mine..air regulator set to 21psi)..I had the tranny built..upgraded internals/Billet triple Disk Converter..Transgo Tugger kit.
lander
Post by lander »
thanks for the help I will work that this week
jermort
Post by jermort »
Yep, will make some real funny diesel noises on that tune, I run the 85 for daily driving. 8)
jammer
'11 6.7 Monster
