U7194 update, again...
CANUCKPREDATOR
Post by CANUCKPREDATOR »
if yours works for you, don't need the newer ones. nothing has changed in the tunes, just adding support for other vehicles.
Poetique
Post by Poetique »
Welp guess I'll be calling in today for a forced restore. My predator right now acts as if it is COMPLETELY incapable of talking to my truck. Can't change the tune, can't modify the one in it, can't run diagnostics, can't read trouble codes, can't do anything.
But before I do that... would it even be worth it? I'm hoping that simply re-flashing the predator will cure it... but if it doesn't I'd be stuck with a stock tune, and I'm not looking forward to 14 MPG again =/
Poetique
Post by Poetique »
Is yall's phone broken? Or are you intentionally ignoring me? lol
phones work fine?
Poetique
Post by Poetique »
::Shrug:: Waited for 20 minutes, nobody answered so I hung up. What's the best low-traffic time to call?
I wish I knew, I'd try to schedule a break for the low traffic time....!
It is truly hit or miss.
Sometimes I think a Bell goes off and people all over the country decide to call at the same time!
Poetique
Post by Poetique »
Booo. Yall should make a universal force restore code or somethin lol. thats why i was callin. I need to force the original backup and try to re-update the predator to cure this "ECKS Fatal Error" crap.
ecks fatal error has nothing to do with the tune.
you cant restore the stock tune without a force?
Poetique wrote:Booo. Yall should make a universal force restore code or somethin lol.
nope, there is no universal "force" password...
it's based off a code that is generated by your predator/vehicle...
which changes every single time the predator is connected/powered-up...
ED
Re: RE: Re: RE: U7194 update, again...
Post by ED »
johan wrote:More support added, including the above file :)
http://www.diablosport.com/downloads/pr ... 9t09h.crom
The update page shows the latest revision as, "u7194-9r09.crom."
What is this update? why isn't it on the updates page?
I am using, "u7194-9r09," in my 06 Corvette. Should I be using, "u7194-9t09h."
Ed
CANUCKPREDATOR
RE: Re: RE: Re: RE: U7194 update, again...
the newer versions are only adding new vehicles, your fine.
Poetique
Post by Poetique »
Yeah I know, that's why I was mentioning a universal one. Having to sit on the phone for endless amounts of time just to get my tune back in my truck so I can re-update the predator is somewhat annoying...
mikel wrote:ecks fatal error has nothing to do with the tune.
Can I what? Hahaha, my Predator is barely conscious that it's even on!
IF I'm allowed to access the diagnostics screen, there are no logging options. As in... I can't even see the options mentioning GM short or GM complete.
Performance Tune option? Forget about it. All it'll do is keep telling me to turn the truck on, even though it's already on.
Try to restore backup? No sir! Same deal as Performance Tune option...
And I know it has nothing to do with the tune, because the tune is fine. But since I can't re-install the predator's CROM without first restoring my backup, I'm screwed, and have to restore the backup just so I can re-install the CROM, and hopefully have a working predator again.
If that doesn't work... meh... what's the warranty on this thing?
Its covered for 2 years....sounds like maybe a wire came loose in your tool or there is a loose pin or wire in the OBDII port...
Poetique
Post by Poetique »
Oy, only 2 years? >_< Any suckers wanna buy a potentially broken predator if I can't get it back workin? lol
concoursd
Post by concoursd »
mike is letting you know that you have a 2 year warranty for repair. I would work with them to diagnose the issue and fix it. If that means a warranty repair then that is what it will take. Keep working with mike.
Return to “Predator GM Gas”
