2008 mustang diablo wont read ignition
ive got a 2008 mustang V6 with a BBK CAI, BBK headers, BBK 70mm TB, PYPES exhaust, and a 75shot of ZEX with a custom tune.. kinda... the diablo turns on and runs through the cycle untill i have to turn the ignition off then back on. it registers the ignition is off, and when i click ok and turn ignition on, the diablo will not register the ignition. therefore i am unable to attain my custom tune for the N2O. any suggestions?
RE: 2008 mustang diablo wont read ignition
If you call support, they'll tell you that you need to send the Predator back to them, then you need to take your car to a dealer and pay them to reflash your car back to the stock factory tune.
I had the car force flashed back to stock by the local ford dealership and i got a diablo swap from the diablo delaer. however it is still having the same issue.. any other suggestions?
What error message do you see?
nightrunner06
im having the same issue with my 2005 mustang v6, error message -12 i believe
it says did not see igntion turn on, check and make sure you do not have a performance module installed. (-10 stock tune did not store)
