Torque Management
chuckie311
Torque Management
Post by chuckie311 »
i just bought your u7192 and it does not let me remove my TQ management..i bought your handheld cause this was the primaryy reason for it and now it wont remove it.. or you going to update the software to allow this and how long will that be... if not i want to return my handheld to get my money back..
2006 chevy 1500 hd 6.0L
johan
RE: Torque Management
Post by johan »
We remove most of it in the regular tune, to completely turn it off you need to go to the adjustable parameters and turn them off.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
chuckie311
there is no way to completely turn it off it does not let you adjust any of the torqure management parameters..what parameters are you talking about...
johan
Post by johan »
http://www.diablosport.com/index.php?mo ... lay&pid=98 describes and names the modify parameters section.
Diablosport INC
chuckie311
i understand that but there is no functions that let you do anything with the torque management once you on in the functions..there is no way to turn it on or off or adjust them..
So you are saying that in the 'Modify parameters' menu, there are no parameters listed as 'Torque Management Abuse Mode' or '%Torque Reduction vs RPM'?
What revision is on this Predator?
chuckie311
you can go in to each one but you cannot change any of the functions they are all set to off.. you cannot turn them on or off or modify them in any way....ill have to look tonight when i get home and give you the revision number..
this is whats listed:
TM Abuse Mode time limit set to off
%Torque Reduction vs RPM set to off
Upshift Torque reduction set to off
We'll look into this tomorrow for sure. Be sure to get me that revision.
chuckie311
thanks mikel.. here is the software ver.2.04 hardware ver. 1.01 ill bring my programmer with me tomorrow just in case you need more info
chuckie311
any update yet guys
Can you post your VIN# so we can test this here on the bench?
chuckie311
sure here is my vin
chuckie311
anything yet guys... i only have a few more days untill i have to return this ..if u cant remove the troque management..
Re: RE: Torque Management
chuckie311 wrote:anything yet guys... i only have a few more days untill i have to return this ..if u cant remove the troque management..
We may need a little time to make this happen, but I can assure you that whatever it takes, we will take care of your issue. We can make you a custom tune if that is deemed necessary.
Give us some time to test this; if we determine there is something wrong with the Predator or the software revision, we will fix it.
If, in a worst case scenario, this issue is not solved (which is not going to happed), we will help you out with returning the tool.
Mike
chuckie311
RE: Re: RE: Torque Management
thanks mike i will wait for you guys to do your research and not worry about returning you great product..in my book you guys are number one for customer service..thanks again..
