analog input
General Trinity Support
98rt_canadian
analog input
Post by 98rt_canadian »
Ever since the new crom my trinity logs do not scale the analog input correctly.
After the update I scaled the analog input for 10 to 18 AFR, and it shows correctly on the Trinity, but when viewed through Dataviewer it scales between 0 and 1.
any ideas?
jimb
RE: analog input
Post by jimb »
I assume your using crom 1r06? Did you also get the new version of Dataviewer 3.3.0.1 Beta?
Jimb
LouZ
Post by LouZ »
where would you get the beta?
98rt_canadian
I tried deleting the gauge from my layout and re-adding but that did not work. Neither did a re-config of the analog in.
tried a new layout with just the analog in that didn't work
deleted all my layouts and redid the analog in config and everything is working again.
Another question tho: Can you log the analog in when pc logging? If so how?
Yes, latest DV Beta supports live streaming of analog inputs.
duster360
Post by duster360 »
98rt_canadian wrote:I tried deleting the gauge from my layout and re-adding but that did not work. Neither did a re-config of the analog in.
Sorry, I forgot to tell you that you had to reconfig the analog input volt min/max. fwiw i didn't have to delete any layouts. Just redo the config and delete/add the gauge.
LouZ
Post by LouZ »
mikel wrote:Yes, latest DV Beta supports live streaming of analog inputs.
How do you get it?
LouZ
Post by LouZ »
How do you get it?
LouZ
Post by LouZ »
LouZ
Post by LouZ »
98rt_canadian
Thx for the replys.
Return to “General Trinity”
