DV - Loss of connection basically locking up DV, this can be a tap to the data cable, car turning off etc
DV - The ability to select and trim logs
DV - The ability to change line thickness on the graphs
DV - The ability to Copy and creat a new gauge page. When you are builting say a graph, and then want the exact same pid selection for a Gauge set up there is no way to just copy as new. The feature of Copy as New gauges or Copy as New Graph woudl be nice and save time.
DV - The ability to select and change multible guages properties say from all gauges to digital or bar graph
DV - Better auto selection of graphing colors, when I have 6 or 7 things logging I shoudl have 3 or 4 things some shade of green. Yes I know I can manaully select and change colors, but doing this every time I make a dashboard is a bit old.
DV - The ability to graph say like :
vs the normalizing you all do ? While I know the above example is only 3 data sets (Time, RPM and Speed ) I have a DH graph thats had 5 pids along with Time/samples.
While these are not DV stuff, Ill postt hem here any ways :
Trinity - The UI bites, I cant be more percice on this atm, I used my buddies for a few hours and it seemed a tad Kludgie
Trinity - The ability to play back a log really bites, you have no way to back up, the Pause/Start/Stop/ forward controls are weak, the play back speeds need more work ( selectability )
Trinity - while I know this unit also log stuff like say AFR or other serial unit, can it log data from say the Innovate SSi-4 ? vs just the innovate AFR or other guage ?
I have more on the netbook, when I dig that out for teh track rental I'llpost up the other stuff I have come across.
-Robert
