7134 9r18 srt-4 log
srt4bad
7134 9r18 srt-4 log
Post by srt4bad »
I just made my first log. as far as i can tell everything is fine, but is there things I can do to improve it?
I have an afr gauge and they stayed at 12 untill the very end and droped to 11.9
stg 1, stock turbo, cai, bfmic, basic bolt ons
https://www.yousendit.com/download/Z01P ... WS92Wmc9PQ
I also have been unable to change the red line and the temp on/off for the fans.
shold I tune with the e-cut out open?
this is a log of 1st and 2nd gear where if found out the revlimit did not change
https://www.yousendit.com/download/Z01P ... RTgwTVE9PQ
thanks
04 SRT-4.AGPwastgate,motor&trans mount,DCR top end modifer,255Wallbo W/rewire,60mm tb,UDP,Needswings dp E-cutout, MagnaFlow exhaust,bfmic,8.5MSD wires, Granatelli coil,5107 NGK plugs, N2MB wot box, AGP Delya 48,DW 1300 inj.,Bosch 044 pump,E-85 and of course a DSP.
srt4bad
try this log
Post by srt4bad »
ok try this. I think I got it this time.
Shortcut to 3rd gear.zip
3rd gear
(618 Bytes) Downloaded 82 times
Shortcut to 1st and 2nd gear pull.zip
1st and 2nd
(664 Bytes) Downloaded 87 times
duster360
RE: try this log
Post by duster360 »
The 2 zips are no good. The .cvs isn't much use but the 1-2 gear link worked.
Notes:
1) LTFT is pulling a little fuel. flashing a tune doesn't clear it so disconnect the battery.
2) AGP wga is weak compared to a well tuned stock wga. its 1-2psi low at 6000. think about it using a stock wga
3) there a bit of knock but I'd get more seat time on the tune to see if its consistant or random. Clearing the -2% LTFT might help a bit.
srt4bad
tune
Post by srt4bad »
did I do these right?
orginal back up.drg
(64.03 KiB) Downloaded 68 times
duster360
RE: tune
Post by duster360 »
I mistyped on that last post.
The .csv file ISN'T of much use. ".log" file is what's needed.
original back-up file isn't of much use either without the performance tune's "last tune written". The file you posted is just the stock S1 tune
