HELP
gizmodo
RE: Re: RE: Re: HELP
Post by gizmodo »
It doesn't matter.
SCGt94
Post by SCGt94 »
First i would determine what the car runs like w/o a tune...revert it back to stock and log it. See what knock retard looks like. If you are still seeing some serious issues, then its something with the car. Bad gas, carbon build up etc.. I would grab a few cans of sea foam run and entire can through the booster line until the car billows out white smoke like a freight train. Next run a can through the tank. What kind of plugs are you running? Hows the ignition system? The pt's are pretty wimpy in the timing department v.s. the srt4 neon...the neon runs quite a bit more timing then the pt cruiser. Post or email me the logs..
I would definitely invest in a wide band...its the BEST modification you can do to this car hands down.
Don
2002 WS6
ptgtrialto
Post by ptgtrialto »
Alright I will go back to stock and run a log... Running stock plugs... They have about 2000 miles on them...
As far as running more seafoam,could you run it through the pcv hose going into the intake ?????That is where all the oil went..
Another question D360 posed to log open fuel loop fa on the predator... Where or what is this under?? I can t seem to find that one in particular
duster360
Re: RE: Re: RE: Re: HELP
Post by duster360 »
ptgtrialto wrote:Alright I will go back to stock and run a log... Running stock plugs... They have about 2000 miles on them...
Use the link I posted. It shows you the heading where all the PIDs are listed. Some are only available using a laptop(strongly reccomended). If you don't use a laptop just log as many as you can.
ptgtrialto
D-360 and Don @ Diablo ...I am trying to send my file after updating 9r18 & pulling battery cable.... NOT Happy !!!!!!!!! Still pinging & my Knock numbers are even HIGHER than before... also the car seems to be less aggresive @ WOT
ptgtrialto
***Update here is a log on Plain Stock too.... Not much Knk here
Please tell me your opinions..........
Return to “General Support”
