Analog inputs - more info
sfla_srt4
RE: Re: RE: Re: RE: Analog inputs - Need more info
Post by sfla_srt4 »
cool. Il be sure to test it out once its released. Thanks John
c2k
Post by c2k »
does it have to be a stereo plug? I found one that's a mono jack, but hey it's free! I havent hooked it up mainly bc of the weather (temp being -5F to 10F lately). This weekend is gonna warm it up to 40F! whoo-hoo!
SRT-4 DiabloSport Trinity Beta Tester User
johnc
Post by johnc »
I say this without having tested it myself, but the mono jack should be fine, the obvious downside being that both inputs will read the same value.
johnc <at> diablosport.com
c2k
Post by c2k »
I only have 1 item for input and that's just my wideband.
4TEHW
Post by 4TEHW »
Any updates?
Josh - 2005 Black Neon SRT-4
S2R0T044 at srtforums.com
Trinity tuned.
RobAGD
Post by RobAGD »
Ok question about logging the serial stream.
Can the Trinity log the data from say something like an Innovate SSI-4 ?
-R
gizmodo
Post by gizmodo »
Currently the Trinity has two analog inputs. The connector on the back of the Trinity is for serial input, which is what you would need since the SSI does not output an analog signal. Keep bugging DS about serial inputs on the Trinity and maybe they will finally listen and implement it.
RobAGD
Post by RobAGD »
Well isn't that special....
Ok I would almost be happy with a PDF that freaking works.
And why did this get moved to the Dodge Diesel Trinity Sub forum vs the General ?
-R
Re: RE: Re: RE: Re: RE: Analog inputs - Need more info
RobAGD wrote:Well isn't that special....
-R
which PDF is not working?
RobAGD
RE: Re: RE: Re: RE: Re: RE: Analog inputs - Need more info
Post by RobAGD »
Trinity Manual, it just pukes all over itself.
This Laptop, my net book and 2 desktops.
-R
Hmmmm, just opened right up for me Rob, would you like me to email it to you?
Try this:
Manual.pdf
(29.26 MiB) Downloaded 1208 times
RobAGD
Post by RobAGD »
Ill give it ago, but it seems to be looking for something thats not there. And it was a clean download on all those boxes.
-R
RobAGD
Post by RobAGD »
Welp after several trys it seems to have worked, weird as non of the down loads finish 100%
-R
