2007 Yukon Denali -- pinging with Predator Performance tune?
fadhil
Post by fadhil »
fadhil wrote:i have 2008 Yukon Denali and i still have sound of pinging even if fall my tank with 93oct if i use performance tune thant i chose 93 oct i will hear the pinging if i chooce the other tuning there is no pinging sound also after log and the 0.0 it still the pinging
sounds like some rocks rattling around in a tin can
if i use 85 oct tunig or factor tuning no painging
but i i use preformace tuning even after I adjust the injector & wot
can please answer me what is the problem
fadhil
Post by fadhil »
then it sounds like you are not using a high enough octane gas with the performance tune...
the gas you are using with the performance tune is too low of an octane, and the timing/spark advance in the performance tune is too high for it...
you either need to use a higher octane gas in your truck, or use the lower octane tune.
solutionsix
Post by solutionsix »
Just an update that I am still looking at this. I decided to try fuel from a different station. I found out that the 93 octane BP is 10% ethanol even though its not displayed below the octane sticker on the pump. They recently added the 10% stickers to the pumps and now I'm concerned its the fuel. I am trying to run this tank down and am searching for a 92 octane pure gas to put in.
I'll post more logs once i am sure I have run the fuel out and have filled up with something different to review before i make any changes.
pawngod
Post by pawngod »
WELL..???? i am curious how its going as i as experienceing the exact same sounds....and yes..it is k.r. plain and simply too much timing advance on the performance tune. in my non expert opinion,
08 sierra denali 6.2l awd, volant cai, aero 3535 muffler, diablosport.
mikeb33
Post by mikeb33 »
I have a U7194 on order for my 07 Denali so I am interested too.
Can't you just modify the current tune to back off the timing a degree or 2?
2009 300c
HellHound
Post by HellHound »
bizzady bump :twisted:
