custom tune ?
vette.c5
custom tune ?
Post by vette.c5 »
Is it possible to have an optimized tune ?
on my 2007 Z06 :
- Vararam VR-SC1R
- Dynatech headers + cats + x-pipe (stock catback)
RE: custom tune ?
do some logging and get your fueling dialed in correctly... info is here on how to do that:
other than that, if you want more of a custom tune with additional tweaks/adjustments made to your tune file to get you more performance, click on the "DiabLew Tuned!" logo in my sig for cost and info about getting a custom tune for your car.
vette.c5
RE: custom tune ?
Post by vette.c5 »
just need custom tune at this time
I read on some forums that vararam + predator results on a too lean condition
and on others forum, than long tubes cause too lean condition without any tune. i don't understand why :roll:
while logging with the trinity (perf tune not installed), my AFR is between 11 and 14.75 (stock sensors)
RE: custom tune ?
again, follow the info here about doing some data logs and adjusting your injector slope to get your fueling dialed in correctly...
vette.c5
RE: custom tune ?
Post by vette.c5 »
log done, but, your software is useless for me
windows 7 64bits
RE: custom tune ?
what software - the Dataviewer???
hmmm.. works perfectly fine for this guy on his Windows 7 64-bit...
http://diablosport.com/index.php?name=P ... 743#111743
vette.c5
RE: custom tune ?
Post by vette.c5 »
dataviewer works fine, but dslogredux don't
RE: custom tune ?
aaaah...
yeah, we're workin' on an update....
we've got our best man on it!
:lol:
Grumpy_Aero_Guy
Re: RE: custom tune ?
Post by Grumpy_Aero_Guy »
vette.c5 wrote:log done, but, your software is useless for me
windows 7 64bits
Useless? I guess you didn't try too hard....
Option 1)
Install the software as is (32 bit version). It will install in c:\Program Files (x86) and will run perfectly...
Option 2)
If you don't believe that will work, then do this
If you have Win7 x64 Pro, or above, download the XP virtual machine from MS (it's free and works great)
http://www.microsoft.com/windows/virtual-pc/
Install in XP32 virtual machine within Win7. It will install and run fine there as well...
If you don't think that will work, then
Option 3)
Assuming you chose Win7x64 Home Premium (not sure why you would choose a 64bit OS lower than the Pro version given the still prevalent 32 bit software out there), PM me and I can send you an x64 version.
It's still a beta, but has tested out fine so far.
Now, if you are in an administrator account, you're good.
If not, install it from an elevated state as an administrator. To learn how, check Start-->Help and Support and search on "iinstall as administrator".
---or--- (recommended)
elevate your user account to an admin account and create a back-up administrator account.
So many choices, so little time....
The SOFTWARE isn't useless to you--- as much as the operation of your OS isn't quite familiar to you... :D :D
DSLogRedux.com
vette.c5
RE: Re: RE: custom tune ?
Post by vette.c5 »
You're right, I didn't try hard
but option 1 tried and after analyzing logs : nothing recommanded, just a message about an error
what was the error message??
Grumpy_Aero_Guy
Re: RE: Re: RE: custom tune ?
vette.c5 wrote:You're right, I didn't try hard
OK... so the software DID install....
Can you,
1) Post the log
and/or
2) a screen shot or transcription of the error.
Are you in an administrator account? PLEASE install it from an administrator account.
IF yes, and it is a system error (not a DSLogReduc generated error)...
uninstall DSLogRedux, Uninstall the Microsoft .Net Framework 3.5
reinstall DSLogRedux. DSLogRedux will automatically prompt you to install the framework. Make sure you are connected to the interent, and make sure any routers/firewalls are configured to allow you do download and install from microsoft.
I also recommend turning User Account Control OFF for the install. Actually, I recommend turning it OFF all together, but that's another post/discussion.
If it is a DSLogRedux error, please post the log so I can look at it.
What kind of machine? What OS (Win 7 x64 Home Premium/Pro/Ultimate?)
DSLogRedux.com
vette.c5
RE: Re: RE: Re: RE: custom tune ?
Post by vette.c5 »
OS : W7 pro 64
tried without any change : error message
tried in XP compatibility mode : error message
tried in XP compatibility mode as administrator : no error message, but "no data" everywhere
tried in virtual XP : "no data", with my log, or with the test one
uninstalled from W7, so, no error screenshot
that was about security access to folders and others
my log size is 9Mo
vette.c5
Post by vette.c5 »
vette.c5
Post by vette.c5 »
the log
20091105.zip
C6 Z06
(473.65 KiB) Downloaded 346 times
Return to “Trinity GM Gas”
